6 members (DavidR, Graham, G4FUJ, MATTMOG, John07, Lordofthewings, John V6), 346 guests, and 41 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
2Sharp Offline OP
Installed a new battery and my battery ran down. I noticed every now and then you hear a tick and the tachometer moves up and down. Is this normal? I assuming that is what is running the battery down when it sits.
Thanks
2017 M3W Sport Green
No ticking for me...
1. I use a CTEK connected to the 12v accessory port in the car. Never had a problem starting after its been on this (on original 3 yr old battery)...
2. When overnighted at RTTC twice this year and the battery failed to start the car on both occasions. I took their suggestion to check and top up the battery - found the water levels low. Carry a Lithium booster pack in case of issues on travels though...
2Sharp Offline OP
Thanks. Maybe just better to use a tender charger. The ticking is very odd. Very intermittent timing wise and takes about 5 minutes. It is like a pulse of electricity going through to the tack.
2Sharp, what model of Morgan do you have & what year is it?
1994 +8, BMW Calypso Red.
How do you open the boot?
I will admit to this, but I thought Morgan batteries were either sealed for life, no fill or gel type. Is that wrong, if so I better get out to the garage and have a look.
Reg
2Sharp Offline OP
I have a 2017 Morgan 3 wheeler.
No ticking or flick of the tacho on my 2013 M3W. Suggest something is not quite right there. Try removing a fuse at a time to see what circuit is causing the "tick" as a start. Even with the immobiliser fitted your battery shouldn't drain in less a month, if it's in good condition.
2Sharp Offline OP
Well after a couple years and a dead battery a couple times I finally figured it out. I replaced the voltage regulator with the Harley version and the tick is gone.
Ahhh, yet another thing to be aware of!
2Sharp Offline OP
I spoke too soon. The tick is still there. I think the battery was just low. It is very odd.
