4 members (Bishmog, Simon, Paul F, Alistair), 350 guests, and 87 robots.
+8Rich 76
Topics49,869
Posts837,665
Moggo
#552046 06/01/19 09:02 AM
TBM Offline OP
Anyone had any experience using them on steel rims?
I reckon there's about 30mm+ space between tyre wall and wing so plenty of space.
Could always go for wider wheels/tyres, but increasing the track slightly would make it easier to straddle all the speed bumps round here!
TBM #552048 06/01/19 09:20 AM
Sox Offline
If you straddle the speed humps in my area you hit the gearbox cross member . Be careful.
Tony
Claret Red +4
Sox #552051 06/01/19 09:29 AM
The Plus 4 has the lowest profile tyres of the whole range of "standard" trad cars. Fit 195/65 R15 tyres and you raise the ground clearance by 10mm.
Depending on the year model you may be suffering from the well known rear spring sag too.
TBM #552052 06/01/19 09:38 AM
I used narrow spacers years ago. They really need locating centrally on the hubs and may need extended studs.
DaveW #552054 06/01/19 09:42 AM
TBM Offline OP
I'm thinking of either 5-10mm spacers and see how much meat is left on the studs, or going for the much larger hubcentric style which bolt onto the hubs and then have their own studs - these are about 25-30mm usually (used these on my Land Rovers).
I think I've read the PCD is 4x130 - does that sound right?
TBM #552056 06/01/19 10:13 AM
Someone will know. I've only had wires on Morgans!
TBM #552196 06/01/19 04:43 PM
I use wheel spacers on My +8 Bitsa with disk wheels. When I converted to Wilwood brakes and rotor the caliper interfered with the wheel. The amount of thread loss on the studs are a concern. But I really do not know how many threads are too few. However I am careful to use a torque wrench to insure they are set properly.
"I think I've read the PCD is 4x130 - does that sound right?" Do not know what "PCD" is. I can guess it is 4 studs X 130mm long.
Button
Button #552197 06/01/19 04:48 PM
Pitch Circle Diameter. Diameter of the circle of the centre line of the bolts.
Best Regards
Lang may yer lum reek
TBM #552200 06/01/19 04:53 PM
4/130 is a fairly common wheel attachment.
PCD means pitch circle diameter.
If you drew an imaginary circle around the centre of the studs or wheel holes that circle is called the pitch circle and it's diameter is the pitch circle diameter or PCD.
Many German cars for example use a 5/112 wheel which means 5 studs or bolts on a 112mm PCD
Doh, Bob beat me to it
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
- My Plus 4 Sport has 205/65R15 tyres. No grounding problems, but luckily there aren't a huge number of road humps around here!
