0 members (), 298 guests, and 33 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 4 of 9 1 2 3 4 5 6 7 8 9
Originally Posted By Craig Jezz
Goodness! They cost a bit
Originally Posted By sailingtom
Just for reference all the defender type headlights are plug and play. Its worth buying the stainless defender mounting ring at the same time as lights though.
Cheers Tom
I will visit the Nolden factory next week, they are based here in Cologne. Why do I need the stainless defender mounting ring? Does the Morgan ring not fit when mounting the LEDs?
This is the new generation Defender LED which includes day light now. On ebay it costs 810 € a pair.
https://www.noldengmbh.de/en/company/news/the-next-generation-ncc-7-bi-led
Found the need to improve lights on my Roadster so investigated full LED headlamps from Powerful UK as discussed above.
I had already fitted their ARV6 LED DRL lamps, but they retain a halogen headlamp bulb. Despite uprating bulb was generally disappointed with results on both main and dip. Lead to believe that anything that fits Defender will fit Morgan so took the plunge and ordered their E approved HL051 pair albeit on sale or return.
Just fitted driver side one without issue, in order to make comparison. These are results against garage wall as weather not friendly enough to try in anger yet.
DRL/sidelights only.
Although the ARV6 type on left employ 12 x LED's in smiley format and look brighter side on, the bluish unfocussed light is dim on wall by comparison with new in DRL/sidelight mode. Here the outer six focused LED's run on half power.
Next we have dipped beam. On the right LED headlamp this comes from single central large lens LED.
Although camera angle favours the old ones its no contest really. Very well defined cutoff with tip up to the left to illuminate kerb. Look above cutoff to see how dark bricks are compared with splatter all around from halogens on left.
Finally main beam from the six outer LED's on full power with central dip remaining on. All seven have total current draw well below single filament of halogen.
Again camera angle favours the old halogen but totally eclipsed by LED's.
Assured they are MOT friendly but only 20 minutes to swap back. Oh and no ECU/BCU issues.
Note that lens does protrude 4mm more through mounting ring than previous, but only noticeable close up side on.
Hi Richard
Can you post a picture front the front of the car, to show what they look like from outside i.e do they still look like normal headlights H4's?
Thanks Mark
2004 Roadster S1 3.0 V6 gone!
Mark
madmax #553117 10/01/19 09:21 PM
Putting the other in tomorrow Mark so will post photo then.
Note Powerful UK offer another headlamp pair (HL730) employing four main LED elements. The two larger lens ones oriented left and right provide dip beam. The two smaller top and bottom, main beam although dip ones remain on as well. The DRL is an outer 'angel eye' ring formed of 80 tiny LED's with diffuser to give solid ring of light. A little more expensive but using Osram LED elements.
The ones I bought came out brightest in their comparative test though and I preferred the look. Note you can choose black rather than chrome background. Thought this would leave my car with pisshole in the snow effect though oops
madmax #553311 11/01/19 08:27 PM
Richard, thanks for the impressive pics. How do you wire the day drive light? Does it get power via the first stage of the switch, so that it is controlled by the side light? Because then the rear lights are also on during the day? Or is it an extra wire that is switched on via the ignition?
madmax #553335 11/01/19 10:58 PM
Both lamps now fitted. Have to admit it gives the car a sinister look but less noticeable in brighter conditions.
In answer to Heinz query, the headlamp flying lead to male three pin H4 type connector has an extra wire with male spade termination. Connecting this wire to sidelight positive feed provides DRL option, with earth return through main headlamp connection.
A 120 mile round trip this afternoon with return mainly in the dark gave excellent test. Confidence inspiring white pool of light on dip with the very well defined cutoff apparently leaving no worries to the heavy oncoming traffic. When I finally had opportunity to try main beam it was night into day 😎
To say I was impressed is a huge understatement happy3
Heinz #553343 11/01/19 11:44 PM
See answer above Heinz.
To add though the current Roadster has front and rear sidelights permanently on with ignition feed, so wiring up as suggested gives automatic daytime lights. There is no further side/position light mode with these particular headlamps and no dedicated feed for such in tbe Morgan loom anyway. Switching the sidelights on with light switch does nothing other than dimming panel lights when driving.
madmax #553344 11/01/19 11:45 PM
Thanks Richard, so does it mean it is the usual side light control on step one of the light switch and the rear lights are also switched on during the use of DRL? which is not an issue in my view.
madmax #553345 11/01/19 11:50 PM
Yes all you are doing with this conversion is replacing factory position light within headlamp with DRL.
madmax #553346 11/01/19 11:50 PM
Okay, we were almost at the same time with our posts. So I would think, with the 4/4 I would switch DRL to the side light, because the 4/4 has no permanent side light on modus.
