Topics49,866
Posts837,588
Posts: 28,900 Likes: 352
Posts: 28,900 Likes: 352 |
Probably the brake light switch (if it's in the hydraulic line) - they don't seem to last long, but there are conversions to alleviate the problem. Congratulations on the new car  Cheers,
Posts: 2,190 |
Hi I am after buying stone guards(mesh) for a 4/4 Morgan driving lights 1996 year. Is there any one out there that could steer me in the right direction, Allso covers for spot lights Moggy lover try John Worrall at heart of England Morgans. I know he does meshstone guards but I am not sure in what sizes. I am sure if he can't hgelpyou himself he can tell you who can ( he also does mail order) www.heartofenglandmorgans.co.uk/ Melvyn Rutter also has an extensive parts department: http://www.melvyn-rutter.net/
GLLHG
Posts: 17 |
I found the brakelight switch just behind the brake pedal, fitted on a bracket near the floor. One of the wires was off, but after fitting this - still no light. All the fuses are fitted inside a aluminium box on the bulkehead, together with relays etc. A lot of fuses, small and large ones - but no describtions what is for what. I found some informations (GoMog) about the fuses for a Roadster 2006 mod, hopefully that will give me a better clue. If anyone have correct information for my 4/4 Sport 2009, IŽll be greatfull.
All the best,
Torstein
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Is there something special about "xx60 xxx" number plates? I have seen quite a number attached to what are obviously much newer cars, yet they don't actually appear to have any meaning... Just curious. Torstein I had missed that your car was nearly new - the comments about the hydraulic switches applies to earlier cars. I hope it is a fuse - good luck with finding the right one!  Cheers,
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Gramham, re. "60" reg. plates, i too have noticed a few on obviously wrong cars and feel that perhaps they are trying to use the 6 as a lower case G, i.e. "g0"
Graham, re. "60" reg. plates, i too have noticed a few on obviously wrong cars and feel that perhaps they are trying to use the 6 as a lower case G, i.e. "g0"
Posts: 17 |
Thanks again folks, and your information Easter makes it much easier for me.  I now have a plastic laminated copy to keep in the car! I always find it interesting to find out how things work, and now there are quite a lot of things to learn about the Mog. I keep on reading&looking.  Torstein
Cheers, Hi Graham 60 plates are current plates for new cars registered between 1st Sept 2010 and 28th Feb 2011
 Of course. I'd worked that one out a couple of years ago, when a pal was mumbling about 'why put all the digits on parking meters for recording registrations onto tickets, there wouldn't be many cars around which had all 10 numbers'... Must have been a bad morning yesterday  I like the g0 or 'go' answer though  I think I'll go back to  Cheers,
