0 members (), 281 guests, and 52 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#55418 27/01/11 06:08 PM
booty Offline OP
Do they fit a cigar lighter on a 2000 +4 from the factory if so where do they put it I know it's a silly question but I can't find one and if I have to put it in myself I would like to know the best place to put it
Thanks Andrew
booty #55419 27/01/11 06:10 PM
Look inside the glovebox. I found mine by accident...........
DaveW #55420 27/01/11 06:30 PM
booty Offline OP
No not in glovebox I don't think I have one so next question how easy is it to put one in
booty #55421 27/01/11 06:41 PM
Usually two wires. 12v +ve and earth, but of the right spec to take the load of whetever you plug into it. Some have third feed for an internal light. They can be taken from a fuse, or even the radio feed (subject to load comment above).
If wired permanent live, can also be used to plug in battery conditioner. Arguably safer to be switched live. If permanent live it's wise to fit a cover to avoid something getting inside & shorting it out.
booty #55423 27/01/11 09:10 PM
Andrew - easy enough to fit but you might want to check this thread for background info.........
"Accessoires an improvements on my Morgan"
good luck
