11 members (Davetherave, Ritchie B, Jens, Robbie, Sir Percival, DazMog, +8Rich, Simon, Stevo666, Luddite, Bishmog),
143
68
Topics49,871
Posts837,675
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Has anyone on here fitted spot lights to a badge bar ? I’m not sure If this has been done before ? I’m thinking of fitting some, but not keen on using the brackets that require holes being drilled into the bodywork. If anyone has done this, a picture would be good so I can see how it looks. My 4/4 has no front bumper or overriders.
Craig Jezz
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Thoughts Quite a strain on the M6 fixings that hold the grill on, especially given extra leverage from indirect fitting of spot lamps to badge bar. Partially hiding the iconic grill and further, a reduction of air flow to rad.
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Too close together to be legal possibly?
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Too close together to be legal possibly? Although someone did do an elongated badge bar with spot light badge bar brackets a while ago when I had my first Morgan I think it might have been Heart of England Morgan but not entirely sure It was about 4 years ago
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The neatest installation I've seen was one which Phil Ledgerwood did, and was a concealed bracket behind the number plate box, with a pair of small spots attached to the top surface of the box. I was almost tempted.
The neatest installation I've seen was one which Phil Ledgerwood did, and was a concealed bracket behind the number plate box, with a pair of small spots attached to the top surface of the box. I was almost tempted. I have removed my plate box Dave.
Craig Jezz
Posts: 122 |
Craig, I have seen somewhere - don't know if it was here or elsewhere, that an italian Morgan specialist does a badge bar specifically for mounting spot/fog lights. Be buggered if I can find it now though. I think a set of 'period' looking spots would look great on the front of my 4/4 but share your reservations about drilling into the bodywork.
2017 4/4 80th Anniversary
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
The neatest installation I've seen was one which Phil Ledgerwood did, and was a concealed bracket behind the number plate box, with a pair of small spots attached to the top surface of the box. I was almost tempted. Any chance to get photo of that, Dave?
Craig, I have seen somewhere - don't know if it was here or elsewhere, that an italian Morgan specialist does a badge bar specifically for mounting spot/fog lights. Be buggered if I can find it now though. I think a set of 'period' looking spots would look great on the front of my 4/4 but share your reservations about drilling into the bodywork. Thanks BobJ
Craig Jezz
Posts: 3,643 |
Try the Italian dealer, Borgi for a spot lamp solution.
