2 members (Julian BB, Clipper), 262 guests, and 57 robots.
+8Rich 86
Topics49,846
Posts837,376
#555526 23/01/19 05:30 PM
2015 Plus 4...
Being a but lazy and not going out to in the cold to measure but I am looking at a new jack (10% off at screw fix at the moment). They have several "low profile" ones which go from about 90 mm and lift to 360 mm. I would always use wood block to save my nice shiny underside and of course axle stand to save me!
Is 90 mm low enough to have room to get decent sized piece of wood in under jacking points?
Biglewey #555530 23/01/19 05:42 PM
Their alloy race jacks fit nicely under a Morgan...well recommended.
1936 Austin Seven Ulster Replica
Biglewey #555531 23/01/19 05:45 PM
Originally Posted By Biglewey
2015 Plus 4...
I’m sure it is
Mine isn’t a low profile one and is higher than that and I can get a block under when jacking up front and back
Biglewey #555537 23/01/19 05:54 PM
“Normal” profile hydraulic jacks are ok, until you need to jack the car up as a result of a picture. That is when you will need the low profile racing jacks.
Rather than wood to protect the underbody I use ice hockey pucks.
Ian
Biglewey #555547 23/01/19 06:21 PM
Yes you'll be fine there is plenty of room for a wooden spreader block in there.
Biglewey #555549 23/01/19 06:25 PM
Front of car should be ok.
For the rear see DaveW posts re a jacking beam if you want both wheels up together or better access to creep under after putting axle stands in place.
I use a beam as the axle is quite a way forward for the jack to reach.
Biglewey #555556 23/01/19 06:48 PM
2015 Plus 4...
I have the Halfords low profile jack, it works well with thick blocks
Craig Jezz
Is that blood on the carpet?
Best Regards
Lang may yer lum reek
paint spillage Bob
Craig Jezz
Biglewey #555617 24/01/19 07:16 AM
Doesn't swmbo complain when you work on the car in the lounge?
