0 members (),
309
Topics49,844
Posts837,360
Posts: 57 Likes: 1
Posts: 57 Likes: 1 |
2015 Plus 4...
Being a but lazy and not going out to in the cold to measure but I am looking at a new jack (10% off at screw fix at the moment). They have several "low profile" ones which go from about 90 mm and lift to 360 mm. I would always use wood block to save my nice shiny underside and of course axle stand to save me!
Is 90 mm low enough to have room to get decent sized piece of wood in under jacking points?
Posts: 308 |
Their alloy race jacks fit nicely under a Morgan...well recommended.
John 1936 Austin Seven Ulster Replica
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
2015 Plus 4...
Is 90 mm low enough to have room to get decent sized piece of wood in under jacking points? I’m sure it is Mine isn’t a low profile one and is higher than that and I can get a block under when jacking up front and back
Posts: 3,643 |
“Normal” profile hydraulic jacks are ok, until you need to jack the car up as a result of a picture. That is when you will need the low profile racing jacks. Rather than wood to protect the underbody I use ice hockey pucks.
Posts: 37,405 Likes: 977
Posts: 37,405 Likes: 977 |
Yes you'll be fine there is plenty of room for a wooden spreader block in there.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Front of car should be ok. For the rear see DaveW posts re a jacking beam if you want both wheels up together or better access to creep under after putting axle stands in place. I use a beam as the axle is quite a way forward for the jack to reach.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
2015 Plus 4...
Is 90 mm low enough to have room to get decent sized piece of wood in under jacking points? I have the Halfords low profile jack, it works well with thick blocks
Craig Jezz
Posts: 6,956 Likes: 116
Posts: 6,956 Likes: 116 |
Is that blood on the carpet?
Is that blood on the carpet? paint spillage Bob
Craig Jezz
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Doesn't  complain when you work on the car in the lounge?
