3 members (Taffmog, DaveW, Bishmog), 295 guests, and 100 robots.
+8Rich 76
Topics49,869
Posts837,665
Moggo
#557822 04/02/19 11:18 AM
jong Offline OP
I have a small rectangular block to the left of the radio in my 2003 Plus 8 (sorry - can't seem to work out how to attach an image!) It is horizontal and approx 25mm x 12mm and black with a black bezel
Looks like maybe a light or switch blank but unlike any others in the car.
Any ideas? [img][img]https://tm-img.com/images/2019/02/04/IMG_0441.jpg[/img][/img]
35th Anniversary Plus 8
jong #557831 04/02/19 12:15 PM
Could it be the infra red sensor for the radio remote controller?
Ian
jong #557839 04/02/19 12:35 PM
jong Offline OP
It is not a part of the radio, but sits perhaps 12mm to the left of it in the same vertical console/panel
jong #557840 04/02/19 12:45 PM
Instructions on how to post images to TalkMorgan
Give us a shout if you get stuck.
jong #557843 04/02/19 01:01 PM
jong Offline OP
Many thanks - very useful [img][img]https://tm-img.com/images/2019/02/04/IMG_0441.jpg[/img][/img]
I have a remote control sensor which is about 20mm square, or perhaps a little larger, which is wired to the back of the radio and attached to the housing next to the radio with double sided tape.
jong #557850 04/02/19 01:21 PM
E
E
switch blank for a heater fan switch??
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
jong #557865 04/02/19 02:21 PM
Hi jong,
Unfortunately you doubled up on the [img] tags as the image icon puts them in for you. This is what it looks like with just the one set.
I agree with Wirewheel and Peter that it's likely an aftermarket wireless remote sensor given manual here
jong #557903 04/02/19 06:23 PM
Do a test.
If you have the handset point it at the radio as it is. If radio functions as expected try the next step.
Cover the rectangular box to blank it. Try the handset again. If it fails then the rectangle is a sensor. If the radio works, blank off the sensor in the radio faceplate and try again. There is a chance that there are two sensors, the rectangle being a piggyback to enhance use.
You could also then clear the rectangle bit and repeat the test.
You have thus sussed out which sensor(s) work.
Have you had a look behind that rectangle? Is there any plug/socket/wiring to it?
jong Offline OP
No handset, but I'll check if it's wired
Thanks
TBH if it is to do with the radio, it can go.
I'll replace it with a second (accessible) 12v or usb socket.
