Posts837,277
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Peter I think your C43 will have a gearbox oil cooler/radiator. Most of the AMG models do. It is a very small radiator in up near the engine rad generally. Both of my previous models have had them. I'll ask the technician at Mercedes; The Plus 8 and all S4 Aeros have a small heat exchanger that uses the engine water to cool the ATF fluid. It is, on Tarka, mounted under the N/S wing, just above the suspension upper arm.
Posts: 2,361 |
Crickey a thermostatically controlled gearbox cooling system this is one serious race car. I have to do this with the gearbox & diff due to heat.
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
Update time folks..... Internal panelling now taking shape.    The dash board is now mounted & looking very neat. Looking forward to having this trimmed in black alcantara   Opinions please...
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Looking good. Black alcantara would be good...non reflective. Will you be putting cooling ducts for the driver in the dash or are there plans for scoops/ducts elsewhere?
Posts: 2,361 |
Looking good. Black alcantara would be good...non reflective. Will you be putting cooling ducts for the driver in the dash or are there plans for scoops/ducts elsewhere? I will be adding drivers cooling. I will design it so its mainly intergrated & hidden as much as possible
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
That's coming together nicely. Black Alcantara probably the best option.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
That's coming together nicely. Black Alcantara probably the best option. +1,
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Great progress she's really coming together now, thanks for the update
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
That does look good. BTW - What are the internal panels made of and how do you stop them "drumming" - assuming that this is an issue.
Looking good. What will the final body colour be, that may have a factor on the choice of alcantara colour for the dash... mustn't clash!!
