10 members (+8Rich, TalkMorgan, MATTMOG, TBM, Ian Wegg, Sir Percival, Mark+4, Luddite, Burgundymog, Neville1),
261
70
Topics49,867
Posts837,624
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Are you talking inside or outside . There's loads of info on the internet, look at Mohair or Twillfast, the other name.
I'm delighted with my offcuts Mohair underpants. Utterly waterproof.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Are you talking inside or outside . BOTH! There's loads of info on the internet, look at Mohair or Twillfast, the other name.
I should have known Yorkshire right through . tighter than two coats of paint Are you talking inside or outside . BOTH! There's loads of info on the internet, look at Mohair or Twillfast, the other name.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
These are the normal linings used with Mohair, its called Dobby The beige one is notorious for marking, but does make a Mog feel brighter inside with the hood up This is the lining to the hood of my Plus 8  It is the same fabric as used to cover the wooden trim pieces on the hood frame. So, do all the Aero Plus 8 cars have a lined hood, or is this another unique feature on Tarka?
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
If you look at the liner and where it gets dirty, you will see that it is where in its folded down state the airflow allows the traffic air dirt flow in. Probably why they make the hood cover which will get dirty instead, that a lot of us don't use and leave back at home!
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Check out Renovo Soft top cleaners. They have some useful tips alongside the products they sell. RENOVO SOFT TOP CLEANER
Bob
Posts: 52 |
I wonder if the entire top and frame can be removed and the inside cleaned, inverted, in tension? Mine is/ (was) the creamy beige fabric.
But not till the weather's a bit more conducive.
35th Anniversary Plus 8
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
These are the normal linings used with Mohair, its called Dobby The beige one is notorious for marking, but does make a Mog feel brighter inside with the hood up This is the lining to the hood of my Plus 8  It is the same fabric as used to cover the wooden trim pieces on the hood frame. So, do all the Aero Plus 8 cars have a lined hood, or is this another unique feature on Tarka? Peter that does look a bit special, I wonder if it's acoustic grade Mohair ?
