10 members (+8Rich, TalkMorgan, MATTMOG, TBM, Ian Wegg, Sir Percival, Mark+4, Luddite, Burgundymog, Neville1), 261 guests, and 70 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,624
Moggo
Page 3 of 3 1 2 3
Posting Desperado
Posting Desperado
Are you talking inside or outside . innocent
Originally Posted By DaveW
There's loads of info on the internet, look at Mohair or Twillfast, the other name.
I'm delighted with my offcuts Mohair underpants. Utterly waterproof.
BOTH!
Posting Desperado
Posting Desperado
I should have known Yorkshire right through . tighter than two coats of paint grin2
BOTH!
Formerly known as Aldermog
Originally Posted By CooperMan
These are the normal linings used with Mohair, its called Dobby
The beige one is notorious for marking, but does make a Mog feel brighter inside with the hood up
This is the lining to the hood of my Plus 8
It is the same fabric as used to cover the wooden trim pieces on the hood frame.
So, do all the Aero Plus 8 cars have a lined hood, or is this another unique feature on Tarka?
If you look at the liner and where it gets dirty, you will see that it is where in its folded down state the airflow allows the traffic air dirt flow in. Probably why they make the hood cover which will get dirty instead, that a lot of us don't use and leave back at home!
Mark - No Longer driving
Check out Renovo Soft top cleaners. They have some useful tips alongside the products they sell.
RENOVO SOFT TOP CLEANER
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
jong Offline OP
I wonder if the entire top and frame can be removed and the inside cleaned, inverted, in tension? Mine is/ (was) the creamy beige fabric.
But not till the weather's a bit more conducive.
35th Anniversary Plus 8
Peter that does look a bit special, I wonder if it's acoustic grade Mohair ?
Page 3 of 3 1 2 3
