5 members (ScotiaSteve, Burgundymog, asbojohn, TeddyAds, BLUE+4), 262 guests, and 49 robots.
+8Rich 82
Topics49,859
Posts837,496
Jonny72
Page 9 of 13 1 2 7 8 9 10 11 12 13
Thank you for the explanation Roger :-)
Thanks Rodger! Looks nice!
one more picture of how it locks together
Rodger
2004 Plus 8 (wife's)
Very cool. I have a similar mounting system for my rack, wondering why they decided to go with the inner tubes?
A well developed part! Morgan? oops
Your paintwork is in good shape, Kankel.
Cause its now much more expensive and is branded. I know as my V2 was just delivered. It does look nice....
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
0
Ordered and received mine after the fact. No instructions supplied so here's how best to do it:
The mounting brackets are beautifully machined and side-specific. This isn't obvious unless you look closely. Placed on the correct side, they fit perfectly horizontal.
- Install the suction cup
- Remove the brackets from the rack
- Install each bracket on its respective upright (you'll know because it's horizontal) but do not tighten.
- Loosen but do not remove all four screws on the rack that attach it to the mounting brackets
- Note that the male posts on the rack can now be slid slightly left or right to match up perfectly with the bracket.
- Test install the 'male' luggage rack into the 'female' bracket ends - Install the two security pins
- Center the loosely assembled rack over the trunk
- Tighten all eight hex screws
It's intuitive and precise.
'17 M3W:
'08 Ural Gear-Up
Nice! Only comment is you'd have thought they could come up with a rounded profile toward the front for the brackets...
Especially as that inner roll hoop post is where the back of your skull bangs against when not wearing a helmet.
Late 2012 M3W
