1 members (Bitsobrits),
426
99
Topics49,859
Posts837,483
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Thank you for the explanation Roger :-)
Posts: 557 |
Thanks Rodger! Looks nice!
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
one more picture of how it locks together
Posts: 557 |
Very cool. I have a similar mounting system for my rack, wondering why they decided to go with the inner tubes?
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
A well developed part! Morgan?
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
Your paintwork is in good shape, Kankel.
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
Very cool. I have a similar mounting system for my rack, wondering why they decided to go with the inner tubes? Cause its now much more expensive and is branded. I know as my V2 was just delivered. It does look nice....
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
Posts: 265 |
Ordered and received mine after the fact. No instructions supplied so here's how best to do it:
The mounting brackets are beautifully machined and side-specific. This isn't obvious unless you look closely. Placed on the correct side, they fit perfectly horizontal. - Install the suction cup - Remove the brackets from the rack - Install each bracket on its respective upright (you'll know because it's horizontal) but do not tighten. - Loosen but do not remove all four screws on the rack that attach it to the mounting brackets - Note that the male posts on the rack can now be slid slightly left or right to match up perfectly with the bracket. - Test install the 'male' luggage rack into the 'female' bracket ends - Install the two security pins - Center the loosely assembled rack over the trunk - Tighten all eight hex screws
It's intuitive and precise.
'17 M3W: '08 Ural Gear-Up
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Nice! Only comment is you'd have thought they could come up with a rounded profile toward the front for the brackets...
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Nice! Only comment is you'd have thought they could come up with a rounded profile toward the front for the brackets... Especially as that inner roll hoop post is where the back of your skull bangs against when not wearing a helmet.
Steve Late 2012 M3W
