10 members (James B W, Hamwich, IcePack, Luddite, JohnHarris, Ncik P, John V6, RichardV6, JMcL, DazMog),
259
71
Topics49,870
Posts837,672
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Indeed it does! I managed to drill off the head of the screw without damaging the plastic lens....  Discovered some clever person had started the screw cross threaded. But with it all apart I was able to re-cut the thread from the back, un damaged side of the brass top hat using a good screw. Now all I need is a new screw!
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Indeed it does! I managed to drill off the head of the screw without damaging the plastic lens....  Discovered some clever person had started the screw cross threaded. But with it all apart I was able to re-cut the thread from the back, un damaged side of the brass top hat using a good screw. Now all I need is a new screw! . Don't go there.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Indeed it does! I managed to drill off the head of the screw without damaging the plastic lens....  Discovered some clever person had started the screw cross threaded. But with it all apart I was able to re-cut the thread from the back, un damaged side of the brass top hat using a good screw. Now all I need is a new screw! well done for sorting this Peter  When I replaced my lenses (for clear) , I managed to source some Allen head , Stainless screws to replace the chromed steel (?) originals as I have found these can (and do ) rust quite quickly. James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 37,435 Likes: 980
Posts: 37,435 Likes: 980 |
"I managed to drill off the head of the screw without damaging the plastic lens.... " Good news Peter well done not easy
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Indeed it does! I managed to drill off the head of the screw without damaging the plastic lens....  Discovered some clever person had started the screw cross threaded. But with it all apart I was able to re-cut the thread from the back, un damaged side of the brass top hat using a good screw. Now all I need is a new screw! well done for sorting this Peter  When I replaced my lenses (for clear) , I managed to source some Allen head , Stainless screws to replace the chromed steel (?) originals as I have found these can (and do ) rust quite quickly. James James, do you remember the size & the supplier? Peter glad you got it sorted.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I put tiny O rings under the heads to try and seal yet another water entry point
well done for sorting this Peter  When I replaced my lenses (for clear) , I managed to source some Allen head , Stainless screws to replace the chromed steel (?) originals as I have found these can (and do ) rust quite quickly. James I'd love to replace them all with little cap head stainless Allen head bolts.... They just look so much neater..... If you have the details....?
Phoned Williams and they have found one for me: I'll collect it tomorrow. But S.S Cap head Allen screws would be MUCH better....
+1. Lets hope James comes back
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
There are two types of thread, although the current one I think is something like 3mm metric.
The standard front screws are longer than the standard rear screws.
I would be interested in allen headed setscrews......
