12 members (riri, chanteclair, Mark+4, philandcolinsmor, Andy, +8Rich, JohnHarris, vincentvg, TBM, Haggispeed, Zach, Moggo), 281 guests, and 40 robots.
+8Rich 91
John V6 49
Posts837,976
So I replaced the radiator on my duratec plus 4 with an aluminium one - it's a long story but I bought it off another owner secondhand.
However, I'm getting a leak from the big top hose. I have tightened it as far as I dare. I wonder if I have gone too far.... is that possible (I used a small socket set just to get in there).
Any tips for getting it to seal before I take it off and have a good look? It's all very annoying as I tightened it up a bit after noticing the leak and I have definitely made it worse. And I am about to go on holiday so will be thinking about this all holiday!!!
Thanks
Nick
I had the same trouble with the alloy radiator on Possum after I installed Evans Waterless Coolant, which seems to find every little orifice. Cured it with Radweld. I would not overtighten the clamp. Are you sure the hose itself is not porous?
Thanks. Well the hose was fine on the previous radiator. I'm wondering if a turn or two of amalgamating tape before fitting the hose might help.
Try using 2 jubilee clips .It worked for me .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
Old tired rubber.
Replace it if you can for piece of mind.
Mark - No Longer driving
There have been a lot of threads on this "problem" and many have had slight leaks when changing from original rads to new aluminium rads.
I had the same on my Zetec and to this day I get a very slight weeping especially on very cold days when the aluminium seems to contract a bit.
Although mine was annoying, it seems to have settled down now and the water loss is negligible.
I changed to silicone hoses at the same time.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
with the clamps at 180° to each other.
Just like the Kerry man who used 2 condoms — “to be sure, to be sure!!”
Robbie
2021 Plus Four -- Helga
211-WX-1433
Richard knows his stuff thumbs this helps to equalise the distortion of the rubber as the clamp is tightened
Ok folks, many thanks.
I'll try this first
