7 members (Gordon D, Simon, Montegue, GrumpyPa, TalkMorgan, Craig Jezz, TBM),
496
143
Topics49,859
Posts837,479
Posts: 8 |
Hi, I have just bought a 2008 Roadster and would like to replace the bulbs in the over wing side lights with LED bulbs. Has anyone done this and what Bulbs should I buy? Also, does this cause any issues with the engine management computer? Any help would be appreciated. Regards Andrew
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Welcome to TM -I see you joined tho in 2017. I hope your Roadster brings multi grande smiles to your life (just a little sense of the new lingo needed...😇) HB
Plus Four Bentley Velvet Red “Grandi P” Golf ehybrid thingy “Toadie” Polestar 4 “Vger”
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
Hi, I put LED bulbs in our 2006 4/4 with no problem, sorry can't remember what they were as just took the old ones out got some from Halfords to match them.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Posts: 310 Likes: 12
Posts: 310 Likes: 12 |
Series 1 Roadster - the original Plus 6!
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
I have replaced all the bulbs, except headlights. Only the indicator bulbs needed ballast resistors.
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
Hi, I have just bought a 2008 Roadster and would like to replace the bulbs in the over wing side lights with LED bulbs. Has anyone done this and what Bulbs should I buy? Also, does this cause any issues with the engine management computer? Any help would be appreciated. Regards Andrew I have a pair of ARV6 style headlamps surplus to requirements. Smiley 12 LED driving/side lights fitted with HI H4 headlamp bulbs.  No fitting issues. PM if interested.
Posts: 8 |
Many Thanks to everyone for replying. Sounds like I can do this without any problems. It was just that it had been mentioned that as the voltage/ amp would be different between the leds and standard bulbs it might upset the engine management computer. Sounds like this isn’t a problem. Andrew
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Doubt it would upset engine management. If the car had a body control unit that might throw up an error though.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
A 2008 Roadster does not yet have a Can-Bus. Therefore it should be no problem to change the lamps. And the power consumption of the LED is lower, which is also good. Because I think the 2008 Roadster has not only no Can-Bus but also no relay behind the light switch. At least my 2014 4/4 has no relay.
