3 members (SteveT, Strathaven, cerealsurfer), 217 guests, and 105 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Page 1 of 4 1 2 3 4
asmog Offline OP
Hi,
I have just bought a 2008 Roadster and would like to replace the bulbs in
the over wing side lights with LED bulbs. Has anyone done this and what
Bulbs should I buy? Also, does this cause any issues with the engine
management computer? Any help would be appreciated.
Regards
Andrew
Welcome to TM -I see you joined tho in 2017. I hope your Roadster brings multi grande smiles to your life (just a little sense of the new lingo needed...😇)
HB
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
Hi,
I put LED bulbs in our 2006 4/4 with no problem, sorry can't remember what they were as just took the old ones out got some from Halfords to match them.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
I also had no problems
Series 1 Roadster - the original Plus 6!
I have replaced all the bulbs, except headlights. Only the indicator bulbs needed ballast resistors.
Originally Posted By asmog
Hi,
Regards
Andrew
I have a pair of ARV6 style headlamps surplus to requirements. Smiley 12 LED driving/side lights fitted with HI H4 headlamp bulbs.
No fitting issues. PM if interested.
asmog Offline OP
Many Thanks to everyone for replying. Sounds like I can do this without any problems. It was just that it had been mentioned that as the voltage/ amp would be different between the leds and standard bulbs it might upset the engine management computer. Sounds like this isn’t a problem.
Andrew
Doubt it would upset engine management. If the car had a body control unit that might throw up an error though.
A 2008 Roadster does not yet have a Can-Bus. Therefore it should be no problem to change the lamps. And the power consumption of the LED is lower, which is also good. Because I think the 2008 Roadster has not only no Can-Bus but also no relay behind the light switch. At least my 2014 4/4 has no relay.
Page 1 of 4 1 2 3 4
