7 members (Ian Wegg, rory kim, JMcL, Mats, Mr K, JohnHarris, Julian BB), 343 guests, and 64 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
SKIPLAN Offline OP
How hard is it to fit Morgan's rear mudguard kit?
0
It's not. If you look at the parts description, it gives a clear picture of the attachment points. It's a DIY job.
'17 M3W:
'08 Ural Gear-Up
You would need a tap and a jack to lift the car up, rather easy
It does add complexity to rear tire removal and reinstallation so while you're at it check to see if the tire needs replacing. Don't waste an opportunity!
Consider riv-nuts instead of tapping directly into swinging arm. Provides more substantial thread and more resiliant to regular removal.
Also consider fabricating one from a plastic trailer mudguard (Indispension MG008). Considerably cheaper and just as good, if not better.
SKIPLAN Offline OP
Thanks everyone for your advice. It looks like it's a DIY job then with some mods on the factory kit.
Here is an earlier thread of fitting a trailer mudguard. Mine is similar but rear end is supported off a bracket spanning the rear of the body. There is enough flex in it to take up body movement relative to wheel. Likely to be cheaper than Morgan kit.
http://www.talkmorgan.com/ubbthreads.php/topics/140519/1
Hi, I had the factory fit the mudguard when my M3W had its first service. All painless if expensive. Six months later what I can only assume were some bolts that sit proud of the mudguard, had worn holes in the rear plastic liner over the rear wheel. It was replaced under warranty and the bolts reworked. So when doing this job yourself make sure that the finished mudguard sits well inside the rear plastic liner.
M3W, Bentley Continental 6.0 Flying Spur, MGB BGT. Beetle Conv, Merc Est, Renault Cleo.
Methinks we all buy Morgans to think how we fix what is not thought through..... or methinks the lady(or laddy) protests too much
Rodger
2004 Plus 8 (wife's)
