11 members (IcePack, ChrisP, dakri, sezznowt, High Hamster, Bitsobrits, James B W, Carbuilder, Tresco, DCH, JMcL), 300 guests, and 81 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Rog #563501 04/03/19 09:33 AM
Originally Posted By Rog
Driving over a cattle grid gets mine out frown
That use to happen on my 4/4. The first time was quite a shock!
1936 Austin Seven Ulster Replica
finally removed horn push,fitted new one,horn still not working.
checked the obvious ie fuse,wiring etc.taken to shouting when cars pull out in front of me.
cheers Marcus
Marcus 2013 4/4 Sport
Have you tried testing the actual horn? They do fail occasionally smile
Hi Graham
Horn works when you earth out steering column ,apparently there is a copper plate behind the steering wheel.I need to check the earth on it fingers crossed.
Hope that is the problem. Good luck! smile
