10 members (JMcL, TBM, Paulxj, James B W, High Hamster, Baristas, Neville1, verysideways, MJF, Graham, G4FUJ),
259
72
Topics49,867
Posts837,622
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Look great
How are you doing the leather engraving? I have a large laser engraver. With the Mulberry leather I engrave the design and then rub in some black paint. I then quickly rub off the paint from the surface leather but at that stage its soaked into the engraving leaving a nice defined design. Crikey, you are well tooled up Engineering party round at your place!
Posts: 1,309 Likes: 5
Posts: 1,309 Likes: 5 |
Cheers Stuart
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Hi Rob Many thanks indeed ! too kind. They will slide up a bit but ive sat in the car and pushed my head back and it hits just above the centre so I dont need to do any adjusting  Looking forward to doing more with the Mog, I have a few ideas I want to try. I just enjoy making things ! Here are some corner protectors I made, next up is matching bonnet strap :-) Nice work! If you apply a triangle of clear film paint protector on each bonnet corner it will prevent micro scratching of the paint.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
A tip......to make the headrestraints easier to slide in and out put car wax on them. It will save the use of force and flying head restraints! Re the bonnet corners...I took mine off as they were rubbing the paint. They are original Morgan ones but I may refit after softening them as they have hardened ( not regularly cleaned/refurbed by previous owners). Will fit rubbing strips on the cowl and check wing clearance.
Well toolled up and getting a new knob....... Ooooh you are awful! But Ilike you.
Top tips, cheers Dave and sospan
You have the makings of a cottage industry there Bonesie, engraved leather accessories have potential. Just don't use the current Morgan Wings. They are vigorously protected by the factory and probably even more so now.
You have the makings of a cottage industry there Bonesie, engraved leather accessories have potential. Just don't use the current Morgan Wings. They are vigorously protected by the factory and probably even more so now. I do similar sort of work in my day to day job. I work from home so have opportunity to get sidetracked, and I easily am Yes, I did read that about the new logo. I certainly wouldn't sell anything with that on it. I did read they dont mind people using the old logo though ?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
They look so much better... Well done!
Posts: 37,429 Likes: 978
Posts: 37,429 Likes: 978 |
That is looking very classy, skilled work indeed Bonesie
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Look great
How are you doing the leather engraving? I have a large laser engraver. With the Mulberry leather I engrave the design and then rub in some black paint. I then quickly rub off the paint from the surface leather but at that stage its soaked into the engraving leaving a nice defined design. Crikey, you are well tooled up Engineering party round at your place! - please put my name down for a place at this party too only joking Bonesie - but ,as Dave mentions, you could certainly get some commissions from those examples. Top work  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
