1 members (CraigL),
228
93
Topics49,860
Posts837,485
Posts: 902 |
LightSpeed, i`m not sure i understand the question.
There is a USB port with Euro 3 and what looks like a 9 pin serial port on the Euro 4. With a lap top, and a suitable connector and protune installed, that should be all you need. John.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Ihave an ODB Reader that plugs into the OBD of my mini cooper and Bluetooths a signal to my smartphone so I can read the faults. It does not interfere with the operation of the system but does read more information in real time, like oil temps water temp etc.
Posts: 902 |
When i asked at Krazyhorse a year ago. I was told that The instruments and such like are not ODB.
On an ODB system one gauge is powered and all the rest plug into that gauge. On the 3 wheeler all gauges are powered separately.
So i am not sure if they are ODB.
The 4 wheelers are. John.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
OBC is a Euro4 requirement.
It's a standard interface so any OBC reader should plug in.
Red Leader
Posts: 902 |
Question. I want to fit 7" round headlights with integrated DRLS, which have separate a fly lead for said lights. Can i connect into the side switch, or do i need to install a separate switch? John.
Thanks John. I suspected that was the case since there is nothing else electronic. Just the engine and its injectors, timing and temperature possibly.
Posts: 902 |
Hi Guys. Question. what holds the main dash panel in place? Not the center section, the bit that's left when the center section is removed. Is it just the 4 bolts, or is there more? John.
Posts: 902 |
What are the correct type of fuel hose clip to use. John
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
Try Powerful UK ltd They have land-rover units which just fit into pods and wiring with no mods Several of us have done this I will try and find product code in the morning
The main headlight will plug straight in.
If you have a built in Daylight Running light (DRL) that will either plug into the sidelight (in which case it's on a switched feed for Eu3 cars) or wired back to a permanently on live.
If you have an indicator in then new headlight unit that will need a new lead fed back and spliced into the indicator wire.
Red Leader
