2 members (ScotiaSteve, Burgundymog), 264 guests, and 40 robots.
+8Rich 82
Topics49,859
Posts837,496
Jonny72
Page 16 of 18 1 2 14 15 16 17 18
LightSpeed, i`m not sure i understand the question.
There is a USB port with Euro 3 and what looks like a 9 pin serial port on the Euro 4.
With a lap top, and a suitable connector and protune installed, that should be all you need.
John.
Ihave an ODB Reader that plugs into the OBD of my mini cooper and Bluetooths a signal to my smartphone so I can read the faults. It does not interfere with the operation of the system but does read more information in real time, like oil temps water temp etc.
When i asked at Krazyhorse a year ago. I was told that The instruments and such like are not ODB.
On an ODB system one gauge is powered and all the rest plug into that gauge.
On the 3 wheeler all gauges are powered separately.
So i am not sure if they are ODB.
The 4 wheelers are.
John.
OBC is a Euro4 requirement.
It's a standard interface so any OBC reader should plug in.
Red Leader drive
Question. I want to fit 7" round headlights with integrated DRLS, which have separate a fly lead for said lights.
Can i connect into the side switch, or do i need to install a separate switch?
John.
Thanks John. I suspected that was the case since there is nothing else electronic. Just the engine and its injectors, timing and temperature possibly.
Hi Guys.
Question. what holds the main dash panel in place? Not the center section, the bit that's left when the center section is removed. Is it just the 4 bolts, or is there more?
John.
What are the correct type of fuel hose clip to use.
Try Powerful UK ltd
They have land-rover units which just fit into pods and wiring with no mods
Several of us have done this
I will try and find product code in the morning
P964 #568020 22/03/19 09:37 AM
The main headlight will plug straight in.
If you have a built in Daylight Running light (DRL) that will either plug into the sidelight (in which case it's on a switched feed for Eu3 cars) or wired back to a permanently on live.
If you have an indicator in then new headlight unit that will need a new lead fed back and spliced into the indicator wire.
Red Leader drive
