1 members (Ian B),
281
97
Topics49,847
Posts837,389
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Hello Ralf, thanks a lot for these photos, this helps a lot to understand what you have done  ... ... and I wish you lots of happy miles Achim +1
Richard 1976 4/4 4 Seater
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
saw this thread through a link.... some great ideas on doing it yourself, and a heck of a lot cheaper
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Since this thread was started several years ago my rear mudguard fitment has developed. It's much more rigid and closer fitting than the original and is mounted to the swing arm using the axle adjusters. The alloy straps stop the plastic mudguard flexing and rubbing on the tyre or surrounding structure.
great stuff, I like the extra bracing, after the oil cooler... maybe my next project, unless my ADHD reminds me I was rebuilding my 1978 Goldwing.... oh look, a squirrel
Posts: 265 |
I've thought of mounting a standard, rubber flap to hang several inches from the rear of the OE guard. I'm rather OCD myself and dislike the crud that can still accumulate on the framing behind it.
'17 M3W: '08 Ural Gear-Up
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Since this thread was started several years ago my rear mudguard fitment has developed. It's much more rigid and closer fitting than the original and is mounted to the swing arm using the axle adjusters. The alloy straps stop the plastic mudguard flexing and rubbing on the tyre or surrounding structure. Nicely done! Did you take photos of the process and the install?
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
For the last 5 years I had it mounted to the frame at the rear but the tyre finally wore through it so now I made ups some brackets out of 15mm copper tube and mounted it to the swing arm.
I used the aluminium "crud catcher" as a template to cut the plastic mudguard down so it protrudes well below the swing arm at the front using the existing bolts and extending the rear with a rubber mud flap.
Rivnuts were used on the swing arm and rubber rivnuts on the mudguard.
All seem fine up to press.
I would add some photos if I knew how.
I too can’t get photos to work. Thanks for the descripton.
Posts: 902 |
Guys, use Tm-img.com to upload images. John.
Hi John
I have put them on TMimage but don't know how to get them onto here.
