6 members (Franky, Jensen1960, WR142LLJPN, SteveT, RubyMog95, Vansrv6), 310 guests, and 130 robots.
+8Rich 77
Topics49,868
Posts837,639
Moggo
DeeDee Offline OP
Hello. So 4/4 with no rear bumpers. Any recommendations on what tool to cut the hole out in the rear valence. Im thinking 40mm hole saw. Anyone recently done this and can advise.
Cheers
Colin (Denises spanner monkey)
DeeDee
2017 Sport Ivory 4/4
Hi, I did mine, it was quite easy actually.
I started with a smaller hole saw as the panel is curved and you have to cut at an angle to be in-line with the chassis if you get my meaning. I then slowly opened up the hole with a round file so as to be sure to be in the correct place.
Take it slow with small steps, make sure you cover the area with masking tape to prevent scratches if you slip and you can't go wrong.
Good luck :-)
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
DeeDee Offline OP
Hi,
Thanks for your advice Paul. Have you any photos?
DeeDee
