7 members (planenut, RichardV6, Elliot, TheRabbit, Ruut Bianchi, Burgundymog, DickJ), 313 guests, and 41 robots.
John V6 68
+8Rich 67
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,046
Captain Morgan, IRWIN
Page 2 of 4 1 2 3 4
There are a couple of threads on this topic
If you search for the titles below, you should get some more info
Toolkit and spares
"Take with" tools and spares
I did that but there was almost zero for the Three Wheeler so that is why I asked here.. id did not however use “take with” as a search parameter so thank you for that tip.
I have also heard thT plugging the rear tire in place is a possibility.
I carry:
Small adjustable wrench
Pliers
Wire cutter w/ stripper
Wire
Electrical tape
Zip ties
Screw driver with multiple bits
Duct tape
Allen wrench kit
Loctite
Cleaning rags
Spare Cotter pin for rear hub
Spark plugs
SAE and metric sockets and wrench
Large adjustable wrench for rear hub nut
Seems like a lot but I've used them all while on the road at various times. This car is constantly trying to shake itself apart so one needs to carry the stuff necessary to tighten it all back up!
I have something like Michael plus I added a tire plug kit (rear tire), Walbro fuel pump, Harley rectifier and timing belt. I would like an extra inner tube but have not got around to it. My fear is breaking down where the parts aren’t available. The good news all of this fits in a small tool bag.
2017 M3W Sport Green
A 4th wheel??? hide
Reg
Online NoMood
If you do the Advanced search you can choose which forum to search, still not great though. Probably the easiest way is to do a Google search for the subject and then look for the Talkmorgan topic on that. That seems to work better than the forum search.
Main spanner sizes are 10, 13 and 19mm. There are some 8mm hex heads too and imperial sizes on the engine so 1/2" AF is worth having. I have a tiny 1/4 drive socket set that covers some small size hex head and Allen sizes, talking of which, metric and imperial Allen keys are very useful.
If you're going somewhere with little traffic and poor phone signal then a scissor jack (Porsche aluminium off of eBay is nice and light) and a spare tube, tyre levers and a willingness to get stuck in may pay dividends! Plus a footpump too in that situation.
Some great suggestions here, thanks all. I was unaware that a Porsche jack was aluminum, certainly better (lighter) that a very old honda car jack.
Plane ut, good suggestion going through Google first to search.
I have not tried popping the bead on a front wheel such as these, only bicycle wheels which i suspect are far more difficult to lever off the rim. Is there a particular recommended tiretool for doing it?
One tool i carry in my mini coopers is a Leather an Tool. The Swiss Army knife on steroids.
I love this forum, you can get useful, informed answers as well as sofistacted humor 😊
Probably the biggest spare that I have (on motorcycles) is that we both ride.
I used to carry just metric, then I sometimes travel with both a Honda and an HD... So my tool box now includes
8, 10, 12, 14, 17 and 19, and then 1/4, 3/8 1/2 (which works for 13), 9/16, 5/8, and 3/4, then metric and SAE Allen, and various screw drivers.... BTW the Japanese Phillips is different than the American Phillips, tire irons, and when with a sidecar a scissor jack and a 12" adjustable (crescent) wrench. And yes a plug in air pump
Rodger
2004 Plus 8 (wife's)
Rodger, that split metric and sae stuff drives me crazy. I had a GMC Suburban that required both and younever knew which one you weregoing to need until you tried it. With the 3 wheeler i suspect only the engine would require sae wrenches.
With the good previous suggestions i found a Thread that had a wealth of information on parts and ideas.
I was unaware that Japanese Phillips head is different than the rest of the world. How does it differ? Blade thickness, width and depth?
Page 2 of 4 1 2 3 4
