2 members (MartO, gomog),
325
94
Topics49,872
Posts837,704
Posts: 8 |
Hi guys,
I've got a 75 4/4, and for some reason it keeps changing it's mind how much fuel I've got. It seems to be affected by both engine speed and road speed.
If I'm driving, at motorway speeds, it'll drop by about a 1/4 of a tank. Stop and sit at idle for a minute or so and it rises up again.
Sitting at idle working on something else in the garage tonight, it read fine at 1,000rpm, then started to drop (about a 1/4 of a tank again) and when I put the revs up to 2 - 3,000 rpm to get some heat into the engine it rose again.
Does anyone have any ideas? Thanks a lot. Tony.
Posts: 413 |
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
A Morgan of that age probably has a voltage stabiliser unit. This is supposed to suppress voltage fluctuations and stabilise the fuel gauge reading. See item 27 here. http://www.mgocspares.com/acatalog/mgb_instruments.html#a3189W_2d128484A solution is offered here...... http://www.britishv8.org/Articles/MGB-Voltage-Stabilizer.htmLook behind the dash, and if you can locate it, try a replacement. Having said that, this problem persisted on my MGB even with a new unit, and everything else replaced, and I learned to live with it!
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
There's a Lucas voltage regulator on my 72 4/4 which serves the instrument panel. When this fouled up the instruments exhibited similar symptoms to yours. I replaced it with a solid state equivalent off eBay which solved the problem.
1972 4/4 2 Seater
Posts: 8 |
Great stuff guys, I'll have a bit of a rummage behind the dash.
Cheers.
Tony 1975 4/4 4 seater.
Posts: 13 |
I had this problem shortly after buying my 1987 4/4. A call to the Harpers advised I check the earth on the voltage stabiliser. Mine was located behind the dash on the right hand side. A clean of the earth solved the problem. Hope this helps.
Keitha 1987 4/4 BRG OSU 889
