1 members (Carbuilder),
133
36
Old Book
Topics49,940
Posts838,603
Posts: 731 Likes: 58
Posts: 731 Likes: 58 |
I'm in the progress of fitting a cigarette lighter in the glove box so that I can use my phone to use Google maps. In my works van I have a suction type thing that sticks to the window screen, but the MOG has aero screens. Has anyone any ideas of fitting the phone to the MOG.
Navy Dave 1976 Morgan 4/4
Posts: 8,718 Likes: 421
Posts: 8,718 Likes: 421 |
Have a look at this. Just ordered one myself.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Hi Dave I did a thread on this earlier last year but I can’t seem to find it However see photos below of my phone holder that I fitted to the Morgan It’s not everybody’s best position but it works very well for me. I wanted it in a discreet position so I can view glance down and a holder that is fixed without it ruining my dash or being in sight It is attached to a bolt on the underside of the leg tunnel and the phone then nestles very neatly to the left of my thigh just under the dash and still gives room to reach the brake lever
Forgot to say that I then got (after the above photos) a long IPhone charger cable which is plugged into the socket in the glove box, goes out the back of the glove box and I’ve routed it behind the dash and cable tied it to the phone holder stem so I can plug my mobile in on the holder
Here are a couple of photos that show it today The phone holder with the charging wire ready to plug in the phone and the inside of my glove box with the charging wire plugged into the socket and running out the back (Because there is an LED light on the charger, I have to remember to remove it from the socket at night after a run so it doesn’t drain the battery)
Posts: 11,548 Likes: 322
Posts: 11,548 Likes: 322 |
What iPhone model do you have? I ask because many of the mounts are now starting to offer the Qi wireless charging that saves the cable being plugged in if you are using bluetooth to the head unit?
Stewart’s is the best if you can screw it in. There are also longer versions that can mount to the seat mechanism but that can be way out of sight for tapping send/end.
If not then a phone cover with a magnetic label and one of the ball mounts to a flat vertical surface is good. I used this from the coupes windscreen for our EU trip and it never got away. If you don’t have wireless charging the cover is fine. If you do then don’t block the back of the phone. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F172783518630
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
I'm in the progress of fitting a cigarette lighter in the glove box so that I can use my phone to use Google maps. In my works van I have a suction type thing that sticks to the window screen, but the MOG has aero screens. Has anyone any ideas of fitting the phone to the MOG. Assuming you don't smoke why not mount a double USB socket?
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
I moved the socket from the glove box to a unit fitted to the roll bar be the passenger door. Easier to reach & use.
The same effort to mount as a Cigsocket but saving the mucking around with the adapters etc. https://www.amazon.co.uk/CHGeek-Charger-Adapter-Waterproof-Motorcycle/dp/B077XY276Y
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
Just done something similar into a panel where the radio would be (as I don't bother in Mogs) plus a basic cig socket too, so I have all possible options I did however make sure the USB goes off when ign not on, as I assume they drag a bit of power for the LED & volt stepdown circuit
