10 members (Chris Cosher, DickJ, John V6, RedThree, MartinB60, sprinty, GrumpyPa, bmgermany, AndyGoff, Morganmike),
245
96
Topics49,847
Posts837,389
Posts: 51 |
2018 Roadster. Is there such a item as a front fog switch? Or is the same as the rear fog switch? If different is there a part number? Pictures?
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Hi Ed, As previously suggested the parts book as below is a little vague on this and not without errors.   Electrically the rear fog lights switch (34) is identical to the optional front one, and would guess they are one and the same part # E340037 as there isn't one specific to front foglight shown. Placing them one above the other could differentiate between front and rear as the illuminated icon would be the same.
Posts: 1,127 |
There definetely is a front fog switch available at MMC, as i bought one for my 3.7 some time ago.
Wasn´t easy to find thgough, but exists (somewhere)!
Sorry for not having the parts no at hand....
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 51 |
What made it any different then the rear fog switch? Ed
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
It faces the other way!
Posts: 51 |
So you turned it 180 degrees???
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
If you don't have aircon the aircon switch can be adapted as a front fog switch. I solved the problem by replacing the enter dashboard
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
What made it any different then the rear fog switch? Ed Ed, I think the front is simple, just on/off, however a rear fog has to pass through some sort of latching relay so that when the car ign is switched off it de-energises the switch, so that when the ign is turned on again the rear fog will not still be on
What made it any different then the rear fog switch? Ed Ed, I think the front is simple, just on/off, however a rear fog has to pass through some sort of latching relay so that when the car ign is switched off it de-energises the switch, so that when the ign is turned on again the rear fog will not still be on As posted to Ed on another thread the switches are electrically the same, if indeed not exactly the same. As can be seen below both front and rear command the BCU to supply the matching foglight(s) whilst increasing their LED icon brightness, but only when headlights are on.  I suspect in each case it's just a momentary switch that as you suggest, latches the foglight on or off.
