Topics49,859
Posts837,498
Posts: 62 |
Howdy! Nothing in the handbook to show me how to adjust the time in my 2014 Plus 4. The clock hasn't been adjusted since clocks went forward...and I'm clearly failing the initiative test as I can't see anything obvious. (Which no doubt it is!) Help please!
Madame Fifi - 2014 Plus 4 GDI
Posts: 1,948 |
Howdy! Nothing in the handbook to show me how to adjust the time in my 2014 Plus 4. The clock hasn't been adjusted since clocks went forward...and I'm clearly failing the initiative test as I can't see anything obvious. (Which no doubt it is!) Help please! My 4/4 (two years earlier than your +4) has a micro-button under the dash approximately below the clock. Hold to make clock go forward. Easy in Spring +1 hr, in Autumn +11hrs (as you can't spool the clock backwards). I'd expect your car would be similar, but hey - it's a Morgan!
Stuart "There's no skill substitute like cubic inches."
Posts: 671 |
Disconnect the battery and wait until the clock on the car shows the same time as reality and quickly reconnect the battery.
I think my level of Morgan maintenance and knowledge may not be up to the same level as many on here.
Posts: 37,418 Likes: 977
Posts: 37,418 Likes: 977 |
All that matters is that it works for you I have never bothered with a clock in any of my Morgan's, I don't wear a watch either though  .
Posts: 8,672 Likes: 411
Posts: 8,672 Likes: 411 |
Howdy! Nothing in the handbook to show me how to adjust the time in my 2014 Plus 4. The clock hasn't been adjusted since clocks went forward...and I'm clearly failing the initiative test as I can't see anything obvious. (Which no doubt it is!) Help please! My 4/4 (two years earlier than your +4) has a micro-button under the dash approximately below the clock. Hold to make clock go forward. Easy in Spring +1 hr, in Autumn +11hrs (as you can't spool the clock backwards). I'd expect your car would be similar, but hey - it's a Morgan! +1 on above advice assuming it's a Smith's clock. A short push on the under dash button will move hand forward one minute. Hold it, and it motors round in forward direction at ever increasing speed. On my Roadster the button is visible if you peer under dash to right of steering housing and clock itself.
Posts: 62 |
My 4/4 (two years earlier than your +4) has a micro-button under the dash approximately below the clock. Hold to make clock go forward. Easy in Spring +1 hr, in Autumn +11hrs (as you can't spool the clock backwards). I'd expect your car would be similar, but hey - it's a Morgan! Thanks for that TT. Will go looking for that switch! Disconnect the battery and wait until the clock on the car shows the same time as reality and quickly reconnect the battery.  That'll be plan B! Cheers
Posts: 62 |
On my Roadster the button is visible if you peer under dash to right of steering housing and clock itself. Thanks Richard.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Plan C - leave it on GMT (I do that with most of my cars - mainly because radio logs are GMT). It will only be "wrong" for 7 months of the year (not 6 as a local BBC radio presenter stated on Sunday afternoon!).
Posts: 175 |
I have 2014 plus 4. clock adjustment on clock face itself. Two little indents at the bottom of the face, run your hand over the face and you should feel them.
Andy 2014 Morgan Plus 4 VW T6.1 campervan
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
My 2016 Plus 4 has the adjustment on the front of the dial via two pin-holes. Use a pointy instrument (a ball pen will do) in the right hole to move the hands forward, and the left to move back.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
