0 members (), 226 guests, and 100 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 4 of 4 1 2 3 4
Originally Posted By Dab of oppo
Rivnuts were used on the swing arm and rubber rivnuts on the mudguard.
Rubber Rivnuts !
Well I never, suit you Sir.
Very Nice.
Hi Dab of oppo.
With images uploaded on TM-img.
On TM-img site, at the bottom left of the image you want to upload you will see embed codes. Click on it.
Select from the list which code you want.
On this post page, at the top, next to the emoji, click the link button. In the pop-up copy the link. ok it and another pop-up appears. Add the title and click.
Ok, trial and error here. Some will upload an image directly to the page. And some will give you link which you click on and it opens the image in that page.
So
[url=![lo14etrue-colour.jpg](https://www.tm-img.com/images/2018/08/18/lo14etrue-colour.jpg)]My three wheeler.[/url]
[url=[![lo14etrue-colour.md.jpg](https://www.tm-img.com/images/2018/08/18/lo14etrue-colour.md.jpg)]
(https://www.tm-img.com/image/KbQO4)]My three wheeler[/url]
[url=]My three wheeler[/url]
Trial and error, just take five and have a play.
Use this post page to try, and delete it when not needed.
John.
Waldemar #566855 17/03/19 08:41 AM
Waldemar #567108 18/03/19 01:00 PM
I have always thought Saint Augustine described uploading og images well.... it is a "termendum mysteryum"
Rodger
2004 Plus 8 (wife's)
planenut #572133 15/04/19 08:21 PM
Originally Posted By planenut
Since this thread was started several years ago my rear mudguard fitment has developed. It's much more rigid and closer fitting than the original and is mounted to the swing arm using the axle adjusters. The alloy straps stop the plastic mudguard flexing and rubbing on the tyre or surrounding structure.
hard to tell in the picture, but does the strap that goes to the axle adjust have a twist?
Rodger
rcmatt #572157 15/04/19 10:38 PM
Yes it does have a twist through 90 degrees.
rcmatt #572158 15/04/19 10:43 PM
I will second this thought, and to add that I find it odd that uploading images to the Photo Gallery is reasonably straight forward so why not the Posts?
Page 4 of 4 1 2 3 4
