5 members (Graham, G4FUJ, BobtheTrain, mickyb, tommog, TBM), 283 guests, and 29 robots.
+8Rich 96
John V6 50
Topics49,901
Posts838,045
#572567 18/04/19 11:07 AM
My 4/4 with a 1.8 Duratec engine started playing up this morning caughing and sputtering after stopping to get some fuel the engine management light came on but the car quickly sorted itself out. On investigation i came up with the error code PO403 (exhaust gas recirculation control unit)
Any suggestions on resolving the problem greatfully received
Chris
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Chris, they have been known to 'soot up' with carbon deposits, if you're confident enough you can remove the unit and give it a bit of a manual decoke.
Or try some EGR fuel additive in the tank & give it an Italian tune-up
Thanks John I will try the spray first
Tried Wynns egr cleaner and reset the error code unfortunatly the problem remains although it hasn't triggered a error code.
I am debating about removing the valve myself but it looks in a pretty inaccessible location or using a local garage l trust.
Chris
Oven cleaner works well, just avoid any rubber bits.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Rog Offline
I beleave po403 could imply the solenoid is open circuit. A long shot and perhaps you have already tried it but you could try making and breaking the connector a few times? It could just possibly be a dirty connector. Make sure the ignition is off first.
Roger
Got to the bottom of the problem SPARK PLUGS severely corroded no doubt to water laying in the depression on top of the engine. The engine fault code was a red herring, must find a cover.
Chris
Rog Offline
Keith’s old thread may be of interest.
Roger
