1 members (jejemek),
223
35
Topics49,844
Posts837,360
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I wondered if any of you knowledgable folk might know if the cowl is adjustable? The bead/rubber trim keeps popping out on one side of the cowl as it's not being gripped very strongly. Are there bolts or screws on the inside to draw it closer to the body?
+8 4.8
Posts: 31 |
I think you will find that the Bead/Rubber trim should be fixed to the underside of the cowl. The Aero8 car cowls are easy to remove, but I do not know if the fixing is the same for Trad mogs.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
I will have a look at mine tomorrow and let you know but I'm sure someone will come back soon. I am well into my second bottle of red so will have problems unlocking the motor house!!
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
The trads have the beading held by the fasteners. I don't know how the Aeros are held.
Thanks all. The beading seems quite loose - held only by an interference fit rather than having any fasteners. But I’ve yet to attempt any remedy as it’s probably beyond my meagre abilities.
+8 4.8
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
Hello Neil, on most trads, the rubber has an flat part,2.5 cm and is placed with 4 very small revets (2.5 mm )in the cowl.
Stefan
Neilda, Sorry for the delay, I had to do the weeks shopping, a girls work is never done. Anyway, I have had a look at my 2015 Trad and the cowl is held on by 4 fixings/bolts each side so the beading should not come loose. I would suspect that one or more of the fastenings has either come loose or failed. It is probably easiest to remove the grille to get a better look and fix it. Good luck!!
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
I hardly dare post this....but, if it was mine, and assuming you can push it back into place easily, I would place it almost back then run a small amount of thin (water consistency) superglue down it and then put it in the correct position properly. Let dry overnight. Superglue is good with rubber. Or, stop driving so fast! Nick
Hmmm... to glue or screw. One of life's great mysteries.
Thanks for the information on the bolts Reg - if I'm feeling brave I might have a look.
+8 4.8
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Thanks for the information on the bolts Reg - if I'm feeling brave I might have a look. I'd take the cowl off and figure out why one side comes adrift and not the other and then fix it properly. Unless it's how it was fixed originally, and I have no knowledge of the modern cars, glueing it is a bodge.
1972 4/4 2 Seater
