7 members (DCH, teknome, High Hamster, Clipper, nick w, SteveT, Image), 385 guests, and 113 robots.
+8Rich 78
DaveW 52
Topics49,867
Posts837,611
#573766 26/04/19 10:04 AM
E
elogan Offline OP
E
I just bought an "old" 4/4 of 1983 but is like a charm ...
I find it very beautiful ... however it has Lemmerz metal wheels that I do not like too much ... What I would like to change if I can
I have a quick question, did anyone of you have it and change those rims and by what? These wheels have a center distance of 4x130, which limits the possibilities ...
Thanks in advance .
elogan #573771 26/04/19 10:20 AM
I have heard the Lemmerz wheels are from the VW Beetle.
For the Beetles you can get steel wheels and hubcaps without VW badge (baby moon).
https://www.werk34.de/de/radkappen-stahlfelge-4-loch-5-5-x-15-et-25-lochkreis-4x130.html
https://www.machine7.com/product.php?xProd=13501
Painted in the car colour, you get cheap a very classic look, a bit like the Morgans from the fifties:
I have not done this, please ask a specialist for old Beetles and your Morgan mechanic if this is possible.
2003 Morgan 4/4 2-seater
elogan #573806 26/04/19 02:24 PM
Try MWS they would know what you need if you want wires.
elogan #573807 26/04/19 02:25 PM
My ‘82 4/4 has Rostyle wheels, which I believe are of VW Beetle origin. It would be good to swap them for ones with round holes as on earlier 4/4s as l am not a fan of wire wheels.
Don
1982 4/4 4 seater
Jens #573818 26/04/19 02:56 PM
Ray Offline
. Check the inset of the VW wheels that the tires clear the crosshead at the top.
elogan #573859 26/04/19 05:58 PM
Welcome elogan enjoy your car.
Jens #573973 27/04/19 12:21 PM
E
elogan Offline OP
E
Merci , mais je ne recherche pas ce look !
elogan #573975 27/04/19 01:09 PM
The bolt-on Rostyle wheels on the Morgan from the 80’s period come from a rare South African beetle model and are not like “most beeetle wheels” you’ll see. Best alternatives are available off the shelf direct from Minilite or alternatives can be sourced from Image Wheels.
If you would like to fit wire wheels, you’ll need to swap your hubs (at some cost).
cerealsurfer #573978 27/04/19 01:46 PM
Welcome to this forum, I found a post with rostyle wheels on a 4 str, search for post #331766 - 11/01/16 10:56 PM.
I think these where the standard wheels in the 80s, I had them on my 1st Morgan too.
These should fit your car and I assume they were on yours orriginally.
Changing to wire wheels could be costly...
Note when you are in the car, you not see the wheels, and you may get used to it.
Have fun,
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
elogan #573988 27/04/19 02:17 PM
I have a spare set of Rostyles and a set of flat steels to fit if you are interested and a bunch of barely used tyres to suit. Toyo’s 185/55/15 or Yokohama AD08’s
