1 members (ChrisConvertible),
349
72
Topics49,867
Posts837,614
Posts: 12 |
Hi All Mostly my S3 and M3W are behaving but Aero has recently developed a blowing fuse - the 5A one for electric window switches and radio. Initially I could replace the fuse and all would be OK for half an hour or so - radio working and electric Windows working both sides. Then over a bump or on restarting the car the fuse would blow. Then gradually got worse! I removed the driver's door trim and removed the window switch and all looks good. Now (whether coincidence or not) the fuse blows as soon as I turn on ignition. Does this point to the radio? Anyway, my main question is - has anyone else had this fuse blow and can suggest what may be causing it, please?
Posts: 11,531 Likes: 315
Posts: 11,531 Likes: 315 |
Have you checked where the cables run through the door frame into the body as this is a tight pinch and can wear/break the cable insulation. Not easy to do but would be my first thought.
Speaker cable and power window switches both run through this gap.
Posts: 12 |
Thanks - all looks ok - wires are in a black plastic cover that doesn't seem easy to move. No speakers in doors in a standard S3... Will try to remove the cover as I had thought similarly. Is it easy to test for a short with a meter from fuse box to electric window switch?
Beyond my skills level I am afraid. I know my S2 which is largely an S3 with a scared look had this issue. The dealer sorted it as part of some other door panel off work.
Posts: 12 |
So, it was wiring in the door, and not the radio. That's some help. Who was the dealer, Alistair?
