Topics49,871
Posts837,677
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Are you going to not run mudguards? I am real curious to know if they would fit. Pirelli makes a nice tire.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Hey Dan, is there any practical advantage to going to more than 48 spokes if you are not racing?
Thanks for the info on the custom wheels. That loosening the fenders in order to remove a knock off wheel just eats at me. i have my tyres fitted at MWS and they just deflate the tyre. No need to loosen or remove the mudguard (fender). I have to do that to remove the rear tire on my 1978 GL1000
It makes sense that if a person needs to remove a tire/wheel then the tire is probably flat anyway, or the tire needs replacing so deflation is not a big deal.
the other half of it is, when I put in a new tire it has no pressure either so it fits easier. I then re-inflate it after it is on.
the other half of it is, when I put in a new tire it has no pressure either so it fits easier. I then re-inflate it after it is on. That makes sense.
Are you going to not run mudguards? I am real curious to know if they would fit. Pirelli makes a nice tire. They were fieffée with moto cross tubes 4mm I try them this week
Posts: 874 Likes: 157
Posts: 874 Likes: 157 |
first tests with Pirelli : ![[Linked Image]](https://zupimages.net/up/21/20/xzd6.jpg) ![[Linked Image]](https://zupimages.net/up/21/20/2nqg.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
first tests with Pirelli : ![[Linked Image]](https://zupimages.net/up/21/20/xzd6.jpg) ![[Linked Image]](https://zupimages.net/up/21/20/2nqg.jpg) As for the tires, what size are they and do they provide a soft ride? As for the exhaust pipes, two flex joints AND a central mounting point tothe body for the pipe between the flexjoints! How did you do that?
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Will the mudguards fit over the 110/90? Yes - both stock steels and G56 carbon-kevlars.
