0 members (),
296
72
Topics49,870
Posts837,668
Posts: 9 |
Does anyone know whether it's possible to remove the sump without taking the engine out? My concern is the rear part of the Engine, if there are any bolts hidden by the clutch bellhousing. Apart from that it looks like a straight forward job. Primarily I suspect the front and rear rubber parts of the gasket (four gasket parts in total). It's leaking a bit too much.
4/4 from 1973
Morgan 4/4 1973 + Citroën BX 1987 NV Blixt 98cc 1939 + Monark Monarped 1959
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Yes you can, I have removed mine in the past.
Posts: 327 |
I believe that it's possible but not without difficulty. There are a couple of bolts at the rear that are difficult to access. I have the same problem on my Caterham with the Kent Crossflow and i haven't tackled it yet. Just think of the old Crossflow adage, "if there's no oil leaks you probably run out"
