11 members (Cat302, Baristas, aerotaff, vincentvg, IcePack, DJC, jejemek, Image, Vansrv6, Alan Patterson, Ritchie B),
276
75
Topics49,851
Posts837,443
Posts: 465 |
This is one of these 'circle' questions!
It all started because I have bought a Morgan suitcase! But my 4/4 has no luggage rack fitted.
It does not have overriders either.
I have seen there is a luggage rack available for cars with no overriders, but I don't like the look of it, especially with the big 'hoop' at the rear.
I then thought, why not fit overriders, then get a 'conventional' luggage rack that uses the overriders as part of the mounting! Looks a lot nicer IMHO.
My car does not have a spare wheel either... so I would need to find the luggage rack that suits close to the rear bodywork.
So! How easy are overriders to fit to a 4/4 and where can you get them from please!
If it's all too difficult, I will just forget the idea of having the leather suitcase and just put the soft bags behind the seats!!
Cheers,
Pete.
Dark Red 4/4 80th Anniversary
Posts: 2,091 Likes: 71
Posts: 2,091 Likes: 71 |
At least your luggage stays dry and a little more secure behind the seats!
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
It look likes you just need two each of parts 8 & 9 plus fixings, noting that the overrider (8) has a captive M10 stud. The rack then attaches via part 4 which shares the upper overrider fixing, allowing rack to drop into a socket on same, although not sure if this is supplied with rack kit. This from the 2014 on parts manual.
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
My previous 4/4 had the flat back panel and like you I'm not a fan of the hoop bar the ladder rack is attached to. BHM got the ladder rack adapted to fit over-riders.
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Pete, I have to say that the hoop does a good job of protecting the rear from shunt parking.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
You can get the rear tubes and overriders from the factory but it usually takes time. Then you need to cut the holes in the rear valance.
Posts: 465 |
[quote=pete757]. My previous 4/4 had the flat back panel and like you I'm not a fan of the hoop bar the ladder rack is attached to. BHM got the ladder rack adapted to fit over-riders. That look's exactly what I am after... So, fitting overriders means drilling holes in the rear valance? I guess then they are easy to fit?
Posts: 543 Likes: 2
Yes it does. I don't know where you are based but it might worth a call to Brands Hatch Morgans. It was Phil, the parts manager, who got the standard rack adapted to fit the over-riders.
Posts: 465 |
BHM fitted a set of overriders to Mr Bumble. They are well used to this job!
