8 members (Phil63, Ruut Bianchi, High Hamster, CRL, DCH, MJF, John V6, davewhite), 321 guests, and 35 robots.
+8Rich 92
Topics49,839
Posts837,302
Very nicely done...
Do you guys think a pair of these up front would make a significant difference?
Oil cooler I have used is here:
https://www.bikermart.co.uk/Universal-Aluminium-Motorcycle-Oil-Cooler-20cm-x-6cm
The oil return line with the mark R is conected to cooler and from that direct to tank.
Have a nice Day
Andrej
Thanks Andrej👍
Kankel, I assume it’s a liquid cooling radiator, but what was its original purpose and what does the interior of it look like? It does not look fragile.
It is written oil radiator...
I use it maybe 5000km and no problem, cooling is better then before and it does not need lot of work.
Return way, because if something is not 100percent closed you can see oil leak.
More safe for engine 😀
Andrej
Thanks Andrej
