8 members (bmgermany, RedThree, mph, cerealsurfer, Gordon D, TalkMorgan, John Winn, TBM), 216 guests, and 88 robots.
Topics49,847
Posts837,389
#577501 22/05/19 01:03 PM
Bonesie Offline OP
My car under load and over slightly bumpy road wants to grab and release ( Im sure there is a better word for that ) ?
Also with two of is in it, it sometimes bottoms out, not all the time but enough to want to sorted.
I remember reading somewhere that its the leaf springs flexing under load that cause the shudder and adding some beefier springs will sort that out as well as bottoming out ?
Panhard rods, correct me if Im wrong, they stop side to side movement when cornering? Do they do anything for the leaf spring flex ?
I have a plus 4 and I like to accelerate sharpish. Now the front is well sorted I want to sort out the back and hit that zen like place of mechanical resonance in The Captain.
thanks folks
Bonesie
Bonesie
Bonesie #577506 22/05/19 01:26 PM
Sounds like anti-tramp bars are needed more than a panhard rod in this case. This will stop the leaf spring wind-up under hard acceleration and consequent tramping, which I believe is what you described. Needless to say fit in pairs. I only mention this because for a brief period MMC tried to get away with using just one on early Roadsters scared
See here
Bonesie #577509 22/05/19 01:47 PM
Bonesie Offline OP
Ah,Thank you Richard. I have been enlightened ! anti-Tramp bars.
Are they fittable at home by a reasonable spannerer or is there a more in depth fitting procedure?
Bonesie
Bonesie #577513 22/05/19 02:07 PM
Talk to Roger Jones -Rog on TM - I have his Bump-stops fitted to my 2018 Plus 4 and this stops totally any "Bottoming out". I also think it makes the car handle bumpy corners better.
A friend had a lot of "Bottoming" issues and is delighted with Roger's Bump stops which he says makes all the difference
Cheers!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Bonesie #577517 22/05/19 02:43 PM
Ooooh good question, I wondered about that (although I haven’t got the front sorted unlike you).
Another question for me to enquire about at Allon White on Saturday (re cost of fitting anti tramp bars). 👍
HB
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
Bonesie #577520 22/05/19 02:49 PM
I have stiffer springs on the front and 4 seater leaf springs on the rear of my 4/4 which is lighter than your +4 this stopped the bottoming out and gives a much better ride.. Give pete Mulberry at Mulfab or Cain Poulton at Wolf a ring they are both helpful and full of info.
Robbie #577521 22/05/19 02:51 PM
Cheers!!
An absolute must. A genius, simple fix.
Nick
Bonesie #577523 22/05/19 03:00 PM
Bonesie Offline OP
The bottoming out is reasonably rare, usually with two of us in and when we hit those funny long dips !
The thing I really want to sort is the tramping. after that I will look at bump stops and panhard cheers
Bonesie
Bonesie #577530 22/05/19 04:30 PM
+1 for 4 seater 4 leaf springs from Mulfab. Transformed our 4/4. Where previously a local road was limited to 50mph by the car bottoming and tramping, now it is safe at any speed.
I would advise speaking to Mulfab or Cain before you spend any money.
Costock, UK
Disco 5
Bonesie #577557 22/05/19 06:56 PM
Bonesie, This http://www.talkmorgan.com/ubbthreads.php/galleries/555298/Leaf_Springs_&_the_Frame
Is what causes the crash as the leaf spring contacts the ash frame on full deflection.
Rogers bump stops sorted it for me. A very easy fit.
