1 members (Socalm3w), 423 guests, and 39 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Page 5 of 12 1 2 3 4 5 6 7 11 12
2Sharp #512554 10/05/18 10:52 AM
I recently updated my pinion (aka crank) pulley using S&S ‘Timing Belt Pulley Repair Kit’ (PN 370-0015).
As well as the new pinion pulley, this kit also includes three replacement nuts for the cam pulleys. The new nuts have a smooth underside and are designed to be held in place using copious amounts of Loctite 243 as opposed to the original serrated style.
I can only assume that S&S have encountered the serrated nuts coming loose over time so it may be worth fitting the later style nuts if you are doing any other work in the timing belt area.
p.s. Thanks very much to KBMOG for the loan of the ‘special tool’ required to hold the pulleys in position while removing & replacing the nuts. It worked a treat! cheers
Andy
2Sharp #512562 10/05/18 12:17 PM
Glad the tool enabled you to do the job Andy.
I am just curious as to why it is necessary to use alternative nuts that are smooth on the mating face rather than using the original serrated nuts.
Surely loctite applied to the threads of the original nuts would have had the same effect, (if not better), because you would then have the anti vibration effect of the serrations plus the locking effect of the loctite.
Just a thought!
2Sharp #512567 10/05/18 01:06 PM
Good question. I did notice that the serrations dig in to the surface of the cam pulley, leaving a bit of a groove.
Therefore if they were taken off and replaced multiple times the serrations might become ineffective? Just my two penn'orth!
Oh, and there WAS some kind of loctite used on the threads of my serrated nuts too...
Andy
rolsmith #577761 24/05/19 02:27 AM
Do the 569 cams have any impact on how easy the engine turns over when starting? With more overlap I was thinking the 569 cams might help the engine spin over a bit faster.
Late 2012 M3W
KBMOG #577812 24/05/19 10:47 AM
I am considering doing some work in this area - any chance of a picture of this timing tool or quick explanation /drawing ?
My understanding is the pulleys are positioned using the holes through them into holes in the crank case?
Thanks
Graham
Bitsobrits #577818 24/05/19 11:59 AM
Not that I noticed on mine.
The Easy Start feature lowers the compression until the engine fires so the increased lift of the 596 won't make any difference.
Red Leader drive
Chris99 #577824 24/05/19 12:25 PM
+1
2Sharp #577827 24/05/19 01:03 PM
Does the Stage 2 cam upgrade smoothout the running of the engine?
2Sharp #577842 24/05/19 03:13 PM
My engine doesn’t feel any smoother than it did originally. It is after all, a big lumpy V-twin. It does feel stronger when you roll out to make a pass on a slower vehicle.
2Sharp #577850 24/05/19 03:30 PM
I would say it is more tractable and nicer to drive. It just feels smoother somehow.
