1 members (Ian B),
323
101
Topics49,867
Posts837,614
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Welcome Thorsten.
Check that the Bevel Box hasn't been overfilled, that can cause seal leaks. It should only be up to the fill level hole above the drain, about 300ml. For info, the Bevel Box pinion nut is LH thread and the seal is a National Oil Seal 224205. Pinion bearing preload is 18-10 lbs in torque.
From the photos you posted, it looks like your car may benefit from the Steering Comfort Kit as well, to reduce the bump steer, unless you have the matching low riding early Suplex shocks and springs.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 60 |
Posts: 37,429 Likes: 978
Posts: 37,429 Likes: 978 |
Thanks for sharing the pictures of that beauty. Have a good adventure in that lovely area.
Posts: 11,531 Likes: 315
Posts: 11,531 Likes: 315 |
Welcome.
My word that must take some cleaning and maintenance.
Posts: 60 |
Check that the Bevel Box hasn't been overfilled, that can cause seal leaks. It should only be up to the fill level hole above the drain, about 300ml. For info, the Bevel Box pinion nut is LH thread and the seal is a National Oil Seal 224205. Pinion bearing preload is 18-10 lbs in torque. good to know, I'd ordered the seals , when arrived I will unmount the Bevel Box, replace the seal and check the oil level. What I'm wondering - the whole drive train including the gearbox is mounted in rubber bearings - so it is moving while running. The BV is fixed to the frame and it seems to me that the propeller shaft is not variabel in length, isn't that a problem ? From the photos you posted, it looks like your car may benefit from the Steering Comfort Kit as well, to reduce the bump steer, unless you have the matching low riding early Suplex shocks and springs.
I didn't notify any problem with the steering, may be I have the 'early suplex shocks' ? what is the problem in detail ? Thanks Thorsten
Posts: 60 |
Don't forget to add it to the M3W REGISTRY ... done
Posts: 60 |
A great looking car and I like the dashboard. thanks Re the noise on acceleration, check if you still have an alloy rear sprocket. If so this is more likely to be causing the noise than the compensator. the rear sprocket is always changed to the steel version The compensator will rattle at idle or very low revs but quieten down as you accelerate. I hear a brigth metallic knocking/ringing from the front when the the power train is more or less idle while driving. When accelerating or breaking by engine this will not appear.
Posts: 902 |
Thorsten, how many bolts holding the dash to the car? I have something similar in myself.
Posts: 902 |
Hi thono, are you running the car without the gearbox cover? Surely that must make it very noisy, and wet when it rains. The obvious benefit is more leg room.
