0 members (), 238 guests, and 81 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 4 of 4 1 2 3 4
JonnyF Offline OP
Vibrations are about the same but now very smooth power and torque delivery. It pulls away from standstill very nicely.
2018 Morgan 3 Wheeler - Krazy Horse Stage 3 100bhp 110ft lb - Sold
Morgan ARP4
Will be interesting to see a long term test on adding the power to this machine on the parts that generally fail on these Morgans.
JonnyF Offline OP
I have decided to put the car up for sale. If you are interested in the car please get in contact either through Talk Morgan or jonathanflowerday@hotmail.co.uk.
I will be happy to answer any questions about the car.
I'll also be putting a post in the for sale section.
Morgan ARP4
Sorry to hear that. Was it anything to do with the Stage 3?
JonnyF Offline OP
No not at all, the stage 3 made the car so much better. The only reason for the sale is I have my eye on another Morgan.
Morgan ARP4
Something with a top?
JonnyF Offline OP
Yes it will have roof this time. But it needs to just as special and fun to drive.
Morgan ARP4
I have a stage 2 Garage 56 kit (exhausts, intake and ECU) and I am delighted with it. My 2012 M3W would not run properly in summer in the south of France, with appalling pinking over 4000 RPM and really at any large throttle openings when the engine was hot. G56 felt this was probably due to the excessive baffling in the original exhausts, retaining too much exhaust gas inside the cylinders. The cylinder head temperatures on my tyre temperature IR gauge, were reading 180ºC or more. This has dropped to a far more reasonable 130º to 140º post G56.
What I would caution is, if you modify the engine, to change the oil lines from the OEM supplied 100º rated ones to good quality 150º rated lines. After going G56, I measured the oil temp in the tank with my tyre temp IR gauge and it was reading over 110º. I changed to Aeroquip FC332 150º oil hoses, which are not only a lot safer but look nice as well, in blue with red alloy unions. In summer after a hard drive the oil is reading 115º on the oil temp gauge I added, when changing the lines. I use Motul 20W60 V300 Le Mans full synthetic oil, good for 165º, according to the maker's spec sheet.
Wilson
Good tip on the oil lines and temps.
Thanks👍
Page 4 of 4 1 2 3 4
