9 members (hugo, GerardNL, jbk, nick w, John V6, Jon G4LJW, Hamwich, brownbaker, MJF),
565
43
SORN
Topics48,376
Posts813,553
Members9,215
Posts: 327 |
What does the panel think? I have recently lubricated the leaf spring and spring hanger bushes with AC50 followed up with few brush loads of EP90.i'm sure the ride is smoother, What experience do you have on frequency of lubrication of these bits of kit. My pals 20hp 1924 Rolls (ex Mr Bird of Birds Custard Powder) has leather fitted covers over its springs c/w grease nipples which might infer regular attention was needed.
Posts: 35,802 Likes: 476
Posts: 35,802 Likes: 476 |
I do mine annually with white aerosol grease and it quietens them down, some people have been known to lubricate them then wrap them in Denso tape. Quite a few use motor bike chain grease as long as you use something it will be fine they are only cart springs after all  .
Posts: 2,774 |
I'm sure DaveW and others will be along to advise but I've had several cars with leaf springs and have always used motorcycle chain lube spray, it's not very sticky.
Oil and some spray lubes can cause road grit and muck to stick causing wear between the leaves. Wrapping is a good idea to prevent this and holds the grease in.
Not sure if AC50 is good for rubber bushes long term?
Posts: 7,076 Likes: 21
Posts: 7,076 Likes: 21 |
An annual spray of Motor Cycle chain oil works for me on my 2011 4/4
Posts: 321 |
JCK 1960 Plus 4 Roadster
Posts: 2,397 Likes: 14
Posts: 2,397 Likes: 14 |
I’ve used Waxoyl for years. Cheap, works well and has good creeping properties..
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 26,770 Likes: 429
Posts: 26,770 Likes: 429 |
Motorcycle chain oil for me. Take the spare wheel off to get at the rear.
Posts: 3,727 |
Annual Spray with Motorcycle Spray Chain Grease - Tool Tray out for ease of access.
I would worry less about leaf spring wear when I see Grit Covered Bump Springs open to the elements (viz. DaveW's Gaiters)
Posts: 1,030 Likes: 15
Posts: 1,030 Likes: 15 |
I work in a bikeshop (no motorbikes) and don't like the chainspray.
For both bicycles and motorbikes the spray is a little bit glueing that it doesn't "fly away". This means that it it also glues dirt.
I prefer for both bikes and the MOG a light oil as using in household or a cheap engine oil.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
I used to use motorbike chain lube (as listed 'safe for o-ring chains') then you know its safe to blast all the rubber bushes too which tend to creak
I'm finding the new 5 Link squeaks and creaks just as bad as dry leaf springs anyway, I suspect its the numerous bushes in the various link arms
