Topics49,859
Posts837,505
Posts: 60 |
Hi out there , checked all the outside connections, they seems to ok. So I'm afraid something inside is broken/loose - will receive the new rectifier tomorrow :-) At the the moment I have some bigger task to solve ;-) ![[Linked Image]](http://www.aufaxe.de/images/m3w/engine-out.jpg)
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I am guessing that the bigger task is something to do with the rubber doughnut on the floor alongside the clutch????? I also notice that your car has the external clutch slave cylinder, only ever seen that in the parts book but it isn't something you look at often. Good luck. Interested to hear how things go.
Posts: 720 Likes: 21
Posts: 720 Likes: 21 |
[quote=thono]Hi out there , checked all the outside connections, they seems to ok. So I'm afraid something inside is broken/loose - will receive the new rectifier tomorrow :-) At the the moment I have some bigger task to solve ;-) ![[Linked Image]](http://www.aufaxe.de/images/m3w/engine-out.jpg) [/  Are you sure that you get this all together again ?
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
When someone is discussing “an exploded view”, just show them that photo.
Good luck on reassembly.
Posts: 60 |
Are you sure that you get this all together again ? completly sure :-) It's 'only' the engine removed and a part of the drive train disassembled. Dis/Reassembling the Gearbox would be another thing, what could make me nervous ;-)
Posts: 60 |
dont think so , this looks like new opposite the harley compensator what seem to be damaged ... more info here I also notice that your car has the external clutch slave cylinder, only ever seen that in the parts book but it isn't something you look at often. Good luck. Interested to hear how things go.
I'm wondering too, because in the parts book the variant is called clutch 2014 (external) but my car is 2012 ... , may be it was upgraded by an earlier owner ?
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
The carpenters rule on the compensator housing is a nice touch! Seems appropriate for a Morgan.
Steve Late 2012 M3W
Am curious why you removed the panel behind the instruments?
Steve Late 2012 M3W
Posts: 60 |
The carpenters rule on the compensator housing is a nice touch! Seems appropriate for a Morgan. this was only a test, whether everyone is carefully watching my pictures ;-) Am curious why you removed the panel behind the instruments? another story, I changed my dashbord before, so the panel wasn't mounted yet ;-) - nobody will care when the bonnet is on top :-)
