9 members (deano, Julian BB, Alan Patterson, Image, Roady, Clipper, RichardV6, Hamwich, Pittsartist), 279 guests, and 74 robots.
+8Rich 80
Topics49,859
Posts837,511
Jonny72
tom+4 Offline OP
2008 plus 4
Any solutions ?
Mvg tom
I spray a little PTFE aerosol on my sliders and that seems to work. I think any lubricant would do the job for you though.
I use car wax on the pillars on mine. This stops them needing a big pull to remove.....they could fly anywhere!
You could try this, it’s not expensive. I had a squeaky steering column once, problem solved.
Enables friction to be reduced between most surfaces
Eliminates noise and squeak
Craig Jezz
Is it just the passenger side, when you're going too fast ? swmbo
Very good smile
As has been said above, lubricate. However if there is a bit of a gap between the headrest post and the chrome surround on the seat, lubrication alone might not be enough. I have slid a part of a cable tie between the post and the seat surround. Experimentation with the size needed might be necessary. Any excess length can be cut off to hide the remains under the headrest while leaving enough to extract it if necessary.
