Topics49,860
Posts837,486
Posts: 82 |
2008 plus 4 Any solutions ? Mvg tom
Posts: 37,417 Likes: 977
Posts: 37,417 Likes: 977 |
I spray a little PTFE aerosol on my sliders and that seems to work. I think any lubricant would do the job for you though.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I use car wax on the pillars on mine. This stops them needing a big pull to remove.....they could fly anywhere!
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
You could try this, it’s not expensive. I had a squeaky steering column once, problem solved. Enables friction to be reduced between most surfaces Eliminates noise and squeak
Craig Jezz
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
Is it just the passenger side, when you're going too fast ?
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Is it just the passenger side, when you're going too fast ? Very good
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
As has been said above, lubricate. However if there is a bit of a gap between the headrest post and the chrome surround on the seat, lubrication alone might not be enough. I have slid a part of a cable tie between the post and the seat surround. Experimentation with the size needed might be necessary. Any excess length can be cut off to hide the remains under the headrest while leaving enough to extract it if necessary.
