Topics49,866
Posts837,587
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Going completely against my parsimonous nature.....
I've found a box of 9 new old stock Gordon Chrome Vanadium sockets in my shed. 1.250 AF and 1/2" drive
A left over from the days when I used to buy and sell high quality tooling.
These are NEW OLD STOCK and have never been used
If any TM would like one free of charge, drop me a PM, a donation for postage would be welcome
First come first served
Arwyn
Posts: 9 |
Hi, I am trying to remove the castleated nut from the rear of my 2009 plus 4 and I am not sure of the exact size . By using a pair of long nose pliers it looks like 1 3/8 " 35mm . Could anyone confirm this , so that I can buy a new socket. I have loads of sockets but none this size . thanks
Andy w plus4 2009 metallic claret red previous 1970 4/4 orange [ 14 years ]
Posts: 9 |
Hi i removed the front castle nut and its 31mm , it came off easy . the rear nut I cant get off at the moment but at least I know the size of it . Using a pair of pliers wasnt very accurate .Thanks Andymog
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
If you use MODERN sockets, they are „flangedrive“ an usable an metric and imperial nuts with some care.
Older sockets are setting at the edges of a nut. That is a very small and difficult point. Modern sockets hat grip at the flange where much more power can work.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Hi Have just changed the seals on my 1999 +8 BTR Axle. The nut size is 3/4" BSW and the tread form is UNF . Cheers
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 12 |
[quote=andymog]Hi i removed the front castle nut and its 31mm , it came off easy . the rear nut I cant get off at the moment but at least I know the size of it . Using a pair of pliers wasnt very accurate .Thanks Andymog
I am trying to get the size of the rear hub nut on my 2009+4, did you get anywhere with 31mm? we think mine is 33mm as a 32mm socket would not go on 33mm is equivalent to 7/8" UNF
If it‘s 31 or 33mm it isn‘t metric. From 28mm on there only sizes with 0, 2, 4, 6 or 8 ending. So if you look for such a socket it would be imperial. Sometimes (at classic MINIs) there where nuts for imperial threats for to use with metric tools on the aftermarket. If you‘re between 31 and 33mm I think it‘s 1 1/4, but than a 32mm would fit. If you’re more at 33mm it looks like 1 5/16. You can get it here: https://www.minispares.com/product/Classic/Accessories/Tools/TOOL04.aspx?0108&ReturnUrl=/search/classic/Sockets%20.aspx|Back%20to%20search And have a look here: http://matthias-trier.de/umrechnungstabellen.htmGreets René
Posts: 8,678 Likes: 492
Posts: 8,678 Likes: 492 |
The socket I use is 1&5/16 inch AF & as Rene says you can get them from classic Mini parts suppliers as they fit the steering wheel boss nut
Posts: 12 |
BTR axle hub nut socket size is 1&5/16" AF, 3/4 W or, 33mm confirmed by Melvyn :-)
Have a look here: https://www.polymax.co.uk/metric_spanner_sizesAs told 31mm and 33mm aren‘t usual metric spannersizes. This spanners and sockets are the result of the forgotten knowledge of the imperial sizes. If you hab a look in a metric spanner or socketset, there are no 29, 31 or 33 sockets. This sizes are styled to match imperial nuts. If you‘ve got a nut and the the 30mm and the 32mm wouldn‘t fit, you measure it. And how? Metric, or when imperial never you measure 1 5/16… With the relativ new technic of flangedrive spanners and sockets, Doesn‘t matter if the Tool (or the nut) doesn‘t fit 100%. I think it would be worth to keep the imperial sizes! Not only the fizz in the pint bottle. Greets René
