0 members (),
294
40
Topics48,345
Posts813,037
Posts: 1,646 Likes: 1
Posts: 1,646 Likes: 1 |
I always thought that the paperwork when ordering an Aero stated that side pipes were not holomogated and were an after-fit but you paid for 'side-exit preparation'.
Maybe that is just in the UK.
Aero 8 GTN. #10
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Maybe that is just in the UK. I understand you are correct. Of course, in the UK there is no measured noise check in the MOT, and largely little real control of after market modifications. Tarka is rated at 87db at 4725 rpm. At Castle Combe circuit they measured 86db at about 4500 rpm. I believe the car has an absolutely standard exhaust. As there are no silencers after the ones under the running boards below the doors I cannot see that side pipes would make much, if any, more noise.
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
It may have to do with the regulations as to where the sound is measured.
It may have to do with the regulations as to where the sound is measured. True, the UK Homologation test is "drive by", so side pipes might be louder.
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
It may have to do with the regulations as to where the sound is measured. True, the UK Homologation test is "drive by", so side pipes might be louder. Highly likely as the sound pressure wave is travelling directly towards the microphone
It may have to do with the regulations as to where the sound is measured. True, the UK Homologation test is "drive by", so side pipes might be louder. Highly likely as the sound pressure wave is travelling directly towards the microphone Perhaps the solution for the test is to simply turn the outlets so they point under the car.... then turn them back....
Tarka has a single, quite small, polished stainless covered silencer under each running board, with the outlet running to the back, ending in a double outlet. So different again from both the examples in your photos.
Part of the problem may be that what we see externally as a 'silencer' my have a very different construction & baffles/restrictions internally
Some are constructed to be a Silencer, and some are just a Resonator & you can't tell from the nice shiny outer casing
