4 members (Rex_tulips, DCH, RJW, Bunny), 372 guests, and 12 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,359
Members9,215
Rbt Aero8, Salmon, stevends
Phil4/4 Offline OP
Hi I am now ready to fit the front wings on the1969 4/4 I am restoring. Is it normal to fix the wing beading to the “sill” section to hold it in place before fitting the wing and if so what is used . Tacks, panel pins or glue ?
jbk Offline
Did this many years ago on an MGTF inserted all the bolts loosely then inserted the beading and progressively tightened the bolts until it pinched the beading tight no glue or pins involved if I remember correctly.
1993 T16 +4 Lancia Blue.
In 1969 they were tacked in IIRC. No glue.
Phil4/4 Offline OP
Thanks for your help. I had decided that was the way to go . I have seen that on more modern cars use a right angle steel section that clamps the wing to the sill. Was this used on a 69 car or did they use local patch washers to clamp the wing ?
There were three or four machine screws that came through from under the door tread plate and also some flathead wood screws with a small washer in the spaces between, depending on the person fitting it on the day!
Two 1/4 bolts through to the rear wing with a spacer as required and penny washers.
Cheers
